Sand couple spots, cut off transom brace, clean up be hind it and install a stainless steel drain plug, reseal transom with 5200; build and install new transom brace lower and upper; Cut off old bench seat brackets; wash it down; 2 coats Gluvit inside and top of outside. Take it to the lake and see if she leaks. If she doesn't I will start installing aluminum bracing for the floor ( 1.25" square tubing ). Picked up a 6" cut off saw at Harbor Freight for 40 bucks ( saves me from having to rent one and rushing to use it and get it back and all that BS ). Not sure of what all I'm going to do to it, but I'm going to keep it pretty basic b/c I don't think the max load on this boat is to high and I'm 250 lbs, another 50 for the motor, then there is gas tank trolling motor battery ( will go up front ) bait/bait well ( not doing a fish live well ) and the girl friend. will be laying the tubing directly on the stringers start at the second one from the rear and runing them parallel atop of them to about where the second bend crease is attaching with 1/4 x 1/2 aluminum rivets as It gets toward the Front stringer it will be 4" to 6" ( or maybe more ) off the center I' be running A 1 1/2 channel down the inside of the keel line riveted to each stringer and extending past the last one to place my center supports in to and support front decking/ battery, anchor locker.
