jigngrub said:
From the pics, that transom looks real bad right now! You should really fix it now instead of later.
Even if it wasn't bowed out like it is now, the extra reenforcing that whomever did to it is a dead giveaway.
Yeah, it looks pretty bad, but I want to get it in the water to check for leaks first. I'm not planning on running it hard. I just want to check for leaks. That way, I can take the boat to a fab shop to get leaks and the transom fixed at the same time. While boat is off of the trailer I can restore the trailer. I think the main reason the transom is so bad is because this boat has never had a motor toter on it. That 50hp that has been on there isn't too light either.
Aaron Lariscy said:
Looking good man where are you at in Savannah and where do you fish? I live in Sylvania GA and am restoring a bass tracker that is roughly the same size with the intentions of using it to fish the intercostal water ways around Savannah. Maybe we could get together one day and work on a boat or even go fishing... Keep us updated on how it goes.
I'm in Pooler right now, but I will be moving to Port Wentworth later this month. I haven't gotten any fishing done down here yet, but I plan on fishing the Savannah River from Houlihan Ramp which is right off of Hwy 25. I plan to mainly target Striper, but I'll fish for LM if they aren't biting. I wanted to fish the Ogeechee either from Morgan's Bridge or King's Ferry, but with the fish kill in May, I'm not getting my hopes up.
I got the new impeller put in the better lower unit today and swapped the lower units. So now the 35 has the lower unit from the 50 on it. I now have the 35 fully functioning and running on the boat. Idle darn good for sitting for so long. I'm planning on running around tomorrow to get a gasket kit for the water pump. I reused what was in there, but I don't think that it is sealing good enough which is understood. Besides now is no time to cut corners, I was just excited to get the motor running and figured reusing the gaskets was worth a shot.
The more I think about it, I think I am going to strip the boat out sooner than later. I want to take a bare hull to the fab shop so they can fix anything at one time. I know there are two spots at the front that scrubbed the trailer when the bunks were too low.
Just to add a picture since everyone loves pictures. The shredded impeller is from the 35. I suspect that happened when we started the motor a couple of weeks ago so I could decide if I wanted to try it and use it or not. The better shape impeller is from the 50, but only two of the fins weren't broken.
Here is a better shot of the transom just to show the damage.
