My jon boat setup tell me what is wrong
[url=https://www.tinboats.net/forum/viewtopic.php?p=328538#p328538 said:
lckstckn2smknbrls » 05 Sep 2013, 22:55[/url]"]With the 4" of setback your getting from the jack plate I don't think your motor is too high but it might not be at the correct height for your boat motor combo. Drill out a few more of the dimples on the mini jacker and try different heights you my find out your boat needs the motor to be a little lower.
When I first mounted my mini jacker I set it so the anti-cavitation plate was even with the bottom of the hull. The boat ran good so I tried putting a 1" thick wood block on top of the mini jacker. That was a little better so I raised the mini jacker 1" and tried it again with the 1" wood block and finely end did up with the anti-cavitation 2" above the bottom of the hull.
I'll try that and see what I come up with.
Similar threads
