Need your help again. How does this work?
midwestfisher
Again, have a 2005 1700 Lund Explorer.
I am trying to figure the livewells. Have one in front (2nd pic) and one in back.
Have just one livewells pump which only fills the back. I saw "holes" (last pic) in the bow which go directly into the livewells front.
The drain for front comes out at bottom
below the boat. The other drains out transom.
How does the front work without a pump?
Please let me know what you think
They're more than likely fed by the same pump. Could be that someone has disconnected the fill hose to use it as dry storage.
Some boats have a simple livewell, where you pull the bottom plug and water fills the livewell up to the water level, which usually isn't but 4-5", but it's enough to keep fish alive. Water goes in and out and they work surprisingly well.
Otherwise, it may be a non-powered livewell being used as storage. You can always plumb it and get it working again.
