boosted16v
- Joined
- Aug 26, 2012
- Messages
- 6
- Reaction score
- 0
Hello everyone..Im having a lil issue with my 94 Bass Tracker Pro 17..I just got done replacing the carpet and decks, and put the boat back together today..went to fire it up and make sure everything was hooked up correctly, and it wasnt...I have power going to switches, bilge and aerator work correctly, but no power going to ignition switch or gauges. I re-checked all the wiring, and the only wire I could find disconnected is on the cranking battery, it has a inline fuse, and is brown in color, so I'm guessing it is not the original. They had the wire going from the battery, up through a hole at the back of the boat near the light plug-in and running down the side of the boat. Problem is, I cant remember where the heck It went to! which is the problem with doing a project "a little at a time". The fuse panel is still getting power. The PO rigged some of the wiring, and Im trying to get this thing running again, seeing as it worked fine before..I hate to think I traded a bad looking but great running boat/for a great looking but non-running boat.. Since I real wiring diagram for these boats is like trying to catch a unicorn, Im hoping someone has some answers. Thanks, any help would def be appreciated!
