- Joined
- Jul 5, 2023
- Messages
- 177
- Reaction score
- 184
- Location
- Florida
- LOCATION
- Lake Okeechobee/Everglades region of Florida
A little extra hassle but you can cut it out and scab in a new piece of aluminum hopefully?!
The boat does have sentimental value it was my wifes brothers boat. Even so it is not looking real good at all. It is still fixable but will require a lot of work and tender loving care.Sometimes it's wise to bail on project vehicles once you realize it's worse than you thought. Think that's the situation you're now in. Unless the boat has sentimental value, I'd scrap it and find another one.
No one ever said that love is rational. I think it’s the right choice to proceed forward, Sonny1… once complete, that little boat will have a “spirit” that no new or ordinary boat could ever touch! Or few will understand. But you will!Took yesterday off and thought about it. Sentimental value and the amount of work done so far I am moving forward on the little boat. The hole in the hull is no big deal but I know the transit leaks. Have two 650k kits and plan on using that on the seams. Clean everything up really good. Then a position boat so when I apply the goop I can lightly heat it up with propane torch and let the stuff flow into the seam. Saw a video on this procedure awhile back and was impressed. Only one way to find out if it works and that is to do it. Talked to an old fart who did the same to his boat about 5 years ago and he claims no leaks. I also noticed his boat had some patches on it. Looked like a thin piece of aluminum riveted to both sides of hull. He claims that the patches have held for over five years. 3m 5200 and two pieces of aluminum riveted in place. Seen videos on this procedure and had my doubts about it. Apparently it works. I also have a large can of gluvit and plan on using that on seams and rivets inside of boat. One thing for sure I have a lot of work to do prior to priming and painting.
When a repair is needed, people often use whatever is at hand, just to get the job done quick !!Busted my butt today. Overcast skies kept the temperature down. View attachment 115973View attachment 115974View attachment 115975 Some idiot along the life of this boat used carpet glue to seal the rivets and seams. Between that and the truck bed liner in the aft section it has been a ton of laughs. We are getting her done. After I get the entire inside wire brushed we are going to clean the boat with MEK. Very familiar with the stuff and will wear all required gear. Then a rinse with alcohol. More to follow
I got lucky on FB , finding a whole heap of alum. (2.5' x 6',7',8' along w/many small squares 2' x 2' and the like, mostly .125 / 1/8" and a few thinner) from a guy an hour 1/2 away. You might try looking for used scrap there !!With the amount of work and money going into this rebuild been searching for a weld shop that is local and willing to weld on aluminum boats. Found a shop close by that specializes in aluminum welding. Guy says he will not weld on aluminum boats. So I made him a offer. I supply all material for the job and pay him $50.00 dollars for the use of his shop. Paid him a visit yesterday. Shop is located in his backyard and is not much to look at. He has a miller 350 which is pretty much beat up. He was very reserved about the deal. Asked if it was OK to run a few beads and he agreed. Afterwards His attitude changed and we talked for well over a hour about welding. So now I need to order some sheet aluminum.
That looks just like my boat did a couple weeks ago !! Good job and good luck.Well here it is nothing fancy. Only 19 inches off the ground but will work for wire brushing, washing with MEK, Applying sealant to seams and rivets, and painting. Will fit in garage shed so painting will be a breeze. Now we are ready to rock and roll. View attachment 116137
We have made similar restoration rigs for our boat work.........Well here it is nothing fancy. Only 19 inches off the ground but will work for wire brushing, washing with MEK, Applying sealant to seams and rivets, and painting. Will fit in garage shed so painting will be a breeze. Now we are ready to rock and roll. View attachment 116137
