Thank you for the compliment. Going to let the boat set until tomorrow. Around noon tomorrow were going after the hole and getting that fixed.
I haven't welded before but purchased a pre-purchased (box never opened) Lincoln 180i rig from a guy 3hrs away. I lived on the way to the casino boats so his wife talked him into dropping it off on the way to bring her gambling.
lol
I new I'd eventually want to learn to mig alum. & wasn't going to purchase the spool gun. (not enough welding to do for that) I purchased a Teflon torch cable liner instead. More on that later.
I purchased another (aftermarket torch cable) to do steel welding w/ the metal liner and built up enough courage to get started. Sonny, I had problems w/ every step :
1st, I couldn't navigate the new helmet computer. Spent an hour & finally a friend showed me.
2nd, I couldn't thread the wire through the drive wheels & thread the eye of the needle for the torch cable. I backed the tension knob to 0 but didn't notice the fork cam lock that allows the tensioner to flip off to the left. After a while w/that my friend arrived again to show me that and the whole top of the tensioner could flip up. I felt like an idiot.
3rd, the wire would not feed more than 3/4 of an inch into the teflon liner ?? I had tightened the set screw that snugs it so much that the brass fitting on the end was closed. I had to change the teflon liner out for the original b'c the pins on the elect. connector of the aftermarket torch cable meant to run steel where placed "one off" the hole pattern. (may be able to correct that one day in the future)
4th, replacing the teflon liner w/ original steel liner , I couldn't get it past the bend of the steel tube on the gun end of the cable so i spun the tube around back and forth until the liner pushed through.
5th, found out the wires connected to the trigger broke off the pins that the trigger contacts when I spun the end tube (which is connected , clamped to the cable) No drive wheel connection !! (@#$%^&)
6th, figure out how to open the handle , re-solder the pins and re-attach everything.
NOW I'M AN EXPERT IN ALL THINGS WELDING !! (Lincoln 180i , that is)
Next ? To welding !! Oops, lower the helmet you fool (!@#$%^) Well, it looks a bit cleaner if you turn on the 75/25 gas , DUMMY !! Ugh, I mean, plenty of weld & good penetration. Maybe a little too much in a couple places to start off w/but, after resetting dials , more focus , hand bracing and placement , I got what my friend calls a "gorilla weld" !! Heavy , ugly , bumps, out of line mostly but good strong and would suffice. I had to flatten out a couple spots where the bumps were high.
After several weld runs , I got the hang of it and am well on my way to becoming a beginner !! Whoo Hoo !!I I should have pursued this 45yrs ago.
Good luck on the hole repair,
Sincerely ..................
God bless.
