Broncoxlt
Almost there got the front deck and trolling motor mount in tonight. Still need to cut the battery hatch door, plumb and wire the livewell then it well be ready for Saterday.
Broncoxlt said:Picked this up today from the local Marine Liquidator. I think its a SeaArk 16x45. What can yall tell me about it?
Broncoxlt said:The middle bench is out the plan for the rest of the decking is in my head.
The next question is paint or steel flex.
I thought about useing steel flex even though it does not leak at all but if I can save the money on the steel flex and use it for something else that would be great.
I thought about using the tractor paint from tractor supply any thoughts?
russ010 said:Broncoxlt said:The middle bench is out the plan for the rest of the decking is in my head.
save the money for the steelflex for something you actually need... your boat doesn't leak a drop, so i would just go with the tractor paint - you aren't going to be leaving it in the water anyways.
Did you get your mount fixed?
