New Ride
millertime4242 said:
Can you explain your bus bar to me? I'm in need for on on my boat, I went to home depot and saw the terminal bus bar you show in the pictures, and didn't think it would work. But by snaking the wire from terminal to terminal is this turning that into a ganged bus bar? That is brilliant! Can you tell me anything I need to know when making one so I don't screw it up? Is it possible to make one for Neg and one for Pos? How will you keep water from hitting it? Thanks for any info!
I just snaked the wire between the lugs to make it a gang bus bar the small one is for the neg,and the one on the back of the switch panel is for the pos. it will be installed after I get the decking complete so it would be covered from the water.
russ010 said:
Did you get that front seat fixed so that you don't fall back into the middle of the boat again?? :twisted:
Cya Saturday
Ya I got that fixed right after that tournament. Cant wait for Saturday
I love that livewell man, why do you have one tube coming out of the bottom?
drain.. he's got 2 ball valves with that bilge pump. When the red is off, and the black valve is on, it will recirculate... when the black is off and red is on, it will pump out and drain the livewell
