O oigetit Member Joined Oct 24, 2016 Messages 18 Reaction score 0 Jan 29, 2017 #1 I have a 1981 Merc 110. Have never used it or even had it running. I just replaced the impeller. I was checking to make sure the shift positions were correct and found that it will not shift to reverse. Any ideas?
C CedarRiverScooter Well-known member Joined Nov 13, 2014 Messages 1,522 Reaction score 6 Jan 29, 2017 #2 Did you rotate flywheel while trying to move shift lever?
O oigetit Member Joined Oct 24, 2016 Messages 18 Reaction score 0 Jan 29, 2017 #3 That is quite possible but not intentional. How is that a concern? Not second guessing. Due to a head injury I am trying to "re-learn".
richg99 Well-known member Joined Nov 27, 2010 Messages 5,105 Reaction score 37 Location Houston, TX & Crossville, TN Jan 29, 2017 #4 I'm not a motor guy, but I believe that the engine should be running in order for it to shift properly. At the very least, you have to turn the prop. richg99
O oigetit Member Joined Oct 24, 2016 Messages 18 Reaction score 0 Jan 29, 2017 #5 richg99... I wondered about that myself. I will get it in some water and test it. Thank you
stinkfoot Well-known member Joined Feb 5, 2016 Messages 399 Reaction score 2 Location Langley, BC Jan 29, 2017 #6 Like Rich says, try turning the prop to slip it into reverse.
