Sinkingfast
- Joined
- Oct 5, 2014
- Messages
- 270
- Reaction score
- 28
..becha the impeller gave up some rubber..
Sad to hear ... I would remove the t-stat cover and FILL that port/tube going down to the exit with white vinegar or some other solvent to try and dissolve that built-up salt. You might also try some spring steel or wire down that tube chucked up in a hand drill and spun s-l-o-w-l-y to see if it removes anything. Cut a sharp angle on the end but dull the point, so only the sides of the straight cut cuts into anything, you don't want the 'tip' to pierce anything and start drilled a new hole.Uncle Krusty said:I'm back at last. Just talked to the shop. They were not able to get the water check port open. They replaced the impeller after having a hell of a time getting the lower unit off due to corrosion at the bolt holes. It's running cool and water is coming out with the exhaust. They say not to put any more money into it and just run it until it croaks. Not what I wanted to hear. How much other salt damage could there be? I won't be taking it out on the Columbia. I mean, how would I know that it's about to croak and not get stuck out on the water someplace? That motor might be OK as a kicker, but I don't think I want to get very far from the launch.
Uncle Krusty said:Thank you Dale! That impeller was not cheap. I guess it took a long time to get the lower unit off. Glad I didn't try it myself. I'll have to figure out how to get the thermostat cover off. BTW, any choice words on repairing a pinhole leak?
DaleH said:I’ve never run one w/ all vinegar as coolant ... so while ‘wary’, I dunnoh. But I have filled the cooling passages in powerheads w/ vinegar & have left them sit for days and rinse/repeat and have had great luck w/ small OBs running cool or as designed, where they used to run ‘hot’.
If it were mine, I’d try the less drastic/invasive method of filling that port w/ vinegar & seeing what happens ... or would try a household ‘lime or descaler’ product before I’d run the motor in a tub of vinegar. Make sure to flush out the vinegar or descaler solution w/ water. HOT water might help dissolve the crud too! Your arms/back will get a work out from tipping that OB up & over, so be careful!!
Sounds like it needs a tuning ... see the OEM Factory Service Manual attached. It is a 2005 dated Manual but still works for my 90s vintage OB 2-stroke.Uncle Krusty said:It idles rough as all heck, lumpy, lots of vibration and smokes a tad.
