Not a good idea, even if in gear. High revs in neutral to blow out the top bearings, or at least I’ve seen it do so on bigger OBs.Uncle Krusty said:What's the verdict about testing the engine at higher RPMs when it's on the muffs?
You’re always best to do this in the water, to add the exhaust backpressure. Less momemtary & not mich higher, I‘d limit in-gear revs to 1,200 on muffs. In fact I only use muffs to confirm, yup ... she’ll start. I’d never diagnose a motor from muff running.
Did you ever try the Seafoam in the fuel mix regimen I had suggested?
