Well I just got back to working on the boat today(I had to get out and catch some walleyes yesterday while the run is on
. I got the decking cut, it's a product called Last Deck. Essentially tongue and groove extruded aluminum planks that are powder coated. A little pricey but I'll never have to redeck again and I can simply spray it down with a hose to clean it.
I fastened the decking down with #8 SS sheet metal screws. I decided to make the deck on boat shorter than I had originally planned because I thought it would get too much weight over the front taper of the pontoons and ride nose heavy. I'm going to put just a aluminum sheet cap over the front section you can see in the pics. The deck will be about 8.5'. I also decided not to go with any storage for this build as this is boat I will sell and didn't think I'd get the return on it to add a hatch and box. Build 2 I'm keeping and will put a little more into it.
I decided to go with 1" x 3" x1/8" angle for the edge trim. It was about 1/3 the cost of normal pontoon trim and just couldn't justify spending extra. Unfortunately it came a little scratched up so I'll have to buff it up a little when I'm done. I was able to get two sides attached and one corner cap on before I decided to call it a day before a storm rolled in.....plus the Masters is on :LOL2:
I got the corner cap from Marine East based on the post in the mod section for materials. Thanks to whomever posted the link, I really like them and saved a bundle.
I also finally got the second set of pontoons back from my fab guy yesterday and cleaned them up this morning. They turned out pretty good, but he said it was a nightmare of a job to weld aluminum so thin. Only cost me a $100 for the entire job which I thought was a great deal. Here's a pic of one tube. It's the back half of the original and I had him just put a flat nose on the front at an angle.
Should be able to finish boat #1 with only 3-4 more hours work. It goes a lot faster when you don't have to paint anything...
