Oil and water
irishfan
York Co, PA
I ran my 6hp merc in a barrel today. After running it I noticed a brown oil coming from the middle of the prop. It does exhaust thru the prop. Is this just residue from the exhaust or is the gear lube leaking somewhere and it is running out the prop?
I don't want to alarm you, but it just might be gear oil coming through, especially if it's thick.
After draining the lower unit oil on my '76 15hp Johnson, I pulled the prop off. There is a seal that keeps the gear oil from entering the exhaust, which sort of sounds like the issue you've noticed.
It's a VERY simple job, so I suggest you drain the lower unit, pull the prop off, and check the seal. It was a $0.95 gasket at my local marine store, along with $10 for the gear oil. Even if it's not the seal, at least you've maintenanced the lower unit for the year.
Just a suggestion to make sure you don't lose the lower unit...
99% it is unburned fuel/two stroke oil. 2 strokes don't burn as efficiently at idle, thus you are always going to have some unburned crud coming out after idling a while.
1% it is gear lube. If you want to check, just drain and refill your gear lube. If the lube comes out clean, you're good to go. If it comes out milky, you have a leak. If lube is leaving, water will be taking its place, so you will notice the milkiness when draining.
1%? Unburned fuel will most likely be stuck to the housing and would appear black; somewhat like dirt, and resembles a dated spark plug.
A picture might help the situation, but no one knows what's coming out of the exhaust because we're not looking at your motor.
The only way to tell is to check yourself. Brown oil sounds like it is contaminated. We're talking the color of the oil, not particles of unburnt fuel.
Oil + fuel + the cooling water the midsection sees makes brown sludge. Don't ask how but it does. Pull the plug on the lower. If it's not milky don't worry about it. That sludge will clean itslef up.
I'm thinking like everyone else. Pull the plug and check the oil before going too far. Sounds like to me it may just be unburned fuel.
