870 ExpressMag
- Joined
- Jun 16, 2012
- Messages
- 27
- Reaction score
- 2
I have an older two piece hull, 15ft Meyers aluminum boat. The transom wood is soft and I need to replace it. I have a couple questions as Im not sure how to proceed. First questions, most boat transoms are 1 1/2", this one is 2" and doesnt ever look like it's been apart, and the top cap is exactly 2". Is this because the boats older, or because it used to be a side console boat with a larger engine capacity so the transom is thicker? That leads me to the next issue, I want to hang my 3hp evinrude on the back for the no wake lakes we go to, it wont fit on the 2" transom, id like to make the transom thinner, but the top cap is for 2", and I also have a splash well bolted to the inside of the transom, as well as two braces on the boat floor that bolt to the transom wood so a thinner transom wouldnt allow these to bolt up. Also, i know it's not the best pic, but you can see the basics of what i'm dealing with, has anyone ever replaced one of these before? doesnt look as cut and dried as some of the transom jobs on aluminum boats. There is transom wood on the inside, and outside of the boat, im assuming this sandwhiches the aluminum skin. I found marine plywood at Menards, but it's only available in 3/4 or 1/2. so if i rebuilt to 2" thick i would need to make 4 pieces from the 1/2 and glue em all together. if i did the 3/4 and did two pieces. now it's a 1/2' smaller than the top cap and wont bolt up to the splash well and the floor braces
