on board charger...
warf
New guy here but long time lurker. Just purchased a two bank Cabala's onboard charger. It is adjustable for flooded battery's or AGM battery's I have a flooded big motor cranking battery and want to pick up a Cabalas's AGM for the trolling motor so what setting would be the best to use for both battery's, the setting for the flooded or the one for the AGM? Or would it make any difference? The instructions that came with the charger don't address this...warf
IMO i would use the agm setting only because the wet cell will only run you $70 ? to replace if you ruin it but the AGM will set you back $ big bucks
