On off switch for trolling motor/battery
CodyPomeroy
I am looking for a switch for my trolling motor that would prevent it from running while stowed for trailering? I have looked through the search function and didn't what I wanted. I would like it to be inline to battery with terminals, so that I can just use jumpers. No soldering if possible... Thanks.
The only switch that will handle the currnt draw of a TM is going to be an on/off switch by blue Sea or Perko. You can attach wires to them using crimp-on terminals. It would be just as simple to install a plug and unplug the TM when in storage.
maybe something like this, but I'm no electrician.
https://www.delcity.net/store/Battery-Switch/p_794068.a_1
Not positive that this BIG FOOT SWITCH will do the job...but...I've used this same switch to start & stop a number of previous trolling motors. I use it as a momentary switch to interrupt the speed of the motor. Wired into the main line...it might do what you want.
regards, Rich
https://www.google.com/products/catalog?hl=en&ion=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&biw=1284&bih=683&q=big+switch+trolling+motor&um=1&ie=UTF-8&tbm=shop&cid=13632372491122971225&sa=X&ei=ZCGKT-jjMefi2QXTzJDgCQ&ved=0CI4BEPMCMAI
Thank you everyone for the suggestions! I think I will go with the plug.
The drag racers are required to have a total system on/off switch that is mounted/accessible on the outside of their car. Harbor Freight sells 'em.
