Powering fish finder ?
Dhark
Hey guys almost done with my tracker 15/42 build, all I have to do is hook up the fish finder. I have the Minnkota battery box and was wondering as it has a cigarette/ac adapter built in to it can I splice a male cigarette end onto the power cord of the fish finders power cable and use that to power it up? It would be a nice quick and easy connections for powering the unit.
You can do whatever you want. The proper way to do it is to power direct from the battery and add a 3 amp fuse on the +.
[url=https://www.tinboats.net/forum/viewtopic.php?p=332378#p332378 said:
Scott1298 » 18 Oct 2013, 18:26[/url]"]Don't those battery boxes have a fuse built in?
Yes but it's a 10amp fuse and fish finder calls for a 3 amp. But the old car phone charger I am thinking of using has a fuse holder built into it so I can just put a 3amp in that I'm hoping
I find that the cig lighter tend to vibrate and lose contact this will cause issues with the finder
What else will be connected to the battery? Sometimes a trolling motor will cause interference with a ff... but don't let it stop you from trying!
[url=https://www.tinboats.net/forum/viewtopic.php?p=332383#p332383 said:
Scott1298 » 18 Oct 2013, 19:52[/url]"]What else will be connected to the battery? Sometimes a trolling motor will cause interference with a ff... but don't let it stop you from trying!
Yes just the TM on the terminals though
The wires all meet back at the battery posts, so that doesn't isolate the ff. If you have any trouble with your ff hook it to a different battery for a trip and you'll know if that was the problem. I have the same boat and made the decision to run the tm separate from everything else; the tm battery is done way before the ff/stereo/light/bilge battery (that could cause interference too, but on those days I prefer to keep my boat afloat :shock: ).
You can try it on the same battery with the TM but you might/could/will get interference sooner or later. If you don't have another battery on board, then use a 12v deer feeder battery to power the FF. Kayakers use this set up all the time, to save weight, etc., and will power a gps/ff unit all day long. You can build a waterproof box for $10 with quick disconnects for $10.
Thanks guys sounds like a small 12v lawn mower type battery is the way to go
You could also use 8 AA batteries in a battery pack/holder, this is what I use on my yaks. Just a thought. :beer:
The pulse type trolling motors will interfere with the electronics of fish finders if they share the same battery. With the tiny amount of current draw from the finder it can be used safely on the starting battery.
sits in any seatbase and it swivels
[url=https://www.tinboats.net/forum/viewtopic.php?p=334838#p334838 said:
bcbouy » Yesterday, 14:03[/url]"]sits in any seatbase and it swivels
Nice and simple. I have had good luck with the 7 amp batteries but I second having the fuse as close as possible to the fish finder.
I think a lawn mower battery is over kill unless you are going to use it for several days without charging it
Just got a 7 amp battery on amazon with charger for around 30 bucks. PM me if you would like the link.
I have the minn kota box and I hooked my depthfinder to the cig lighter socket. The plug I used has an inline fuse so I could use the correct 3 amp. I've never had any interference with the motor.
I just discovered that my trolling motor "blanks" my FF screen when it's on.
I'm leaning toward the lawnmower battery, too!
Also, I'm adding a Stator to my motor, to add 6 amps of charging, so the mower battery seems the way to go, rather than a smaller battery.
-TH
[url=https://www.tinboats.net/forum/viewtopic.php?p=334886#p334886 said:
23mako » 20 Nov 2013, 10:03[/url]"]Just got a 7 amp battery on amazon with charger for around 30 bucks. PM me if you would like the link.
[url=https://www.tinboats.net/forum/viewtopic.php?p=344772#p344772 said:
acwd » 12 Mar 2014, 21:54[/url]"]Anybody got a link to that battery and charger?
Thanks
Steve
I bought this same battery and it works great.
https://www.amazon.com/Sealed-Lead-...394708585&sr=8-1&keywords=fish+finder+battery
About how long does it last before you need to recharge it? I am looking at doing this in my new boat for a electric only lakes.
Steve
