So tomorrow, I will be replacing my first transom. The one I just removed was encased with aluminum, and bolted in. I assume it has been replaced at some point. Not a 100% sure. Either way, I am concerned that drilling once installed, I may miss the hole on the other side, and not hit everyone exactly. I was thinking of pre drilling every hole with one size bigger bit before installing. Which would be better? Pre drill with bigger bit on the wood only, or wait till the transom is in place, and try drilling through?
Also, there is the two splash well drains. I can get them easy enough. But how do I crimp it once I have it?
Thanks
At the end of this build, I should be able to give advise.
Thanks
