KansasJon
I have a jon boat that I am going to fix-up a little bit. I am thinking it needs a fresh coat of paint. I have searched the forum and am even more confused than when I started. To prep this boat for paint should I
1) Use an orbital sander (What grit? 120?)
2) Use an aircraft paint stripper paired with a power washer
3) Use a wire wheel with my grinder
I also have a hi speed buffer that could be used.
I was thinking that the sander might be best to even out the paint but I think the boat has three coats of paint. The original and two hand rolled coats so it is really thick.
Any opinions would really help out. Plus I need a cover that wont blow off in a blizzard
