bobmwsc
It's come time to replace the transom on my 12' aluminum boat. I had done it years ago but used untreated wood with a bunch of coats of spar urethane. The issue I have is there is no drain and though I've thought of putting one in I don't trust that I won't screw it up. Because if this on occasion the boat fills with water and the transom board sits low enough that it'll be partially submerged for a day or a week or until I remember to siphon it out.
I found someone online selling cutoffs of solid PVC sheets. I was thinking if sandwiching the rear aluminum between 3/4 sheets of the PVC. Would it be rigid enough to hold a 4hp 2 stroke outboard and a trolling motor? I was thinking if need be I could put aluminum c channel around the PVC to stiffen it.
Any thoughts?
Sent from my moto g(6) using Tapatalk
Any thoughts?
