question on 1976 Evinrude part
khughes2345
been lurking on the site for a while. all i can say is i hope my boat looks as good as some of the others on here when it is finished. But now i have found a reason to post something.
i don't know what the part is, but i was hooking up a new throttle cable and i turned on the tiller handle to far and the cast iron crank cracked. its the gear that is connected to the handle shaft on the side of the motor and it turns the other gear for throttle. kinda hard to explain without a picture, but one crank is slotted into another kinda like rack and pinion. any help would be great because i need to order a new one. i will get some pics up of my boat and the part that is broke tomorrow. any help in the meantime would be great! thanks!
Check out this link:
https://shop2.evinrude.com/ext/index.aspx?s1=0957e4d3e289fc0f3de5d93c1a0437b2
Put in your motor info then what your looking for is probably in the "exhaust housing" tab.
thanks for the help, i looked there, but never thought to look in the exhaust housing parts. i think i found the part, but here is a picture of the cracked part.
