I disagree - with the motor up every bump transfers the weight of the motor to the transom. A transom saver is just that - a transom saver. While the motor will still bounce a bit in the down position, it is not nearly as bad as when it is up. From the picture it does not look like you have a lot of clearance between the skeg and the pavement. A brace from the back of the trailer to the lower unit is not that hard to make. Mine is a 2"X2" with a bungee on one end and a U shaped bracket that fits the rear cross-member of my trailer.[url=https://www.tinboats.net/forum/viewtopic.php?p=360086#p360086 said:gillhunter » 19 Jul 2014, 11:02[/url]"] If it locks in the tilted position you can get away without a transom saver.
[url=https://www.tinboats.net/forum/viewtopic.php?p=360245#p360245 said:Analog Kid » 20 Jul 2014, 18:01[/url]"]I always tow my boat with the motor in running position is there a reason anyone should tilt it up other than road clearance?
