Ghostryder65
- Joined
- Mar 21, 2024
- Messages
- Reaction score
- 14
Hello everyone. New here. I have been reading lots of threads here. Great group full of knowledge. This is my first question of will probably be many..lol
My transom was rotted so making a new one. Also removing benches and adding a floor and supports, as well as foam under the floor. My question is can I raise transom since I already have 2 long shaft 15 hp in the garage? My plan is to make the new transom without the cutout. Taking the bottom down between and past the 3 supports. Adding maybe 14-16 gauge aluminum to both sides of the wood. 2 part epoxy will be used to build it. A couple extra through bolts for bottom extensions. I believe that will handle the 25 hp that is planned for later also. Thoughts or advice? 197? Mirrocraft 14'
