I just bought a really nice 1984 Grumman 14 ft. utility v-bottom that I put a new Tohatsu 9.8 on. It's a really sweet setup. Very simple, no carpet, just the aluminum bench seats.
BUT- at certain RPM ranges the hull vibrates like a buzz saw, incredibly loud. I'm pretty good at finding noises, and it does it in two different places that I have found so far at different RPM ranges.
The loudest is where the gunwale cover meets the side sheet metal in one area a few inches long. If I clamp that spot with my hand it helps a lot. This is at about 3800-4200 RPM. The other place is on the rear seat around 2500 RPM. It's not as loud as the gunwale noise but still really annoying. If I push down on the middle of the top sheet metal it stops it.
It is unbearably loud, to the point it sounds like the boat is rattling apart. It happens in a very useful RPM range, so it's not that easy to just adjust out of it.
Are there any cures for this? I have found very little on line for this specific issue. Most recommendations are to add carpeting or other sound-deadening sheets, which I don't think would solve this issue. This is not a boat that is generally noisy like an aluminum boat tends to be. This is very specific spots with very loud resonant vibrations at certain RPM ranges.
Thanks for any help.
David
David
