Rectifier- Regulator failure
InSaneFisherMan
Noticed that my charge voltage was lower than normal. Checked service manual and the regulated voltage should be 13.5-14.4vdc @ 3000 rpm.
Checked charge coil, relays, fuses, ECM, wiring, and regulator.
All were good except, regulator inputs from charge coil. Open, when they should have been .85 - 8.5 ohms.
Will post a follow-up update, when regulator comes in and installed.
  • screen-20241014-142035~3.mp4
    561.2 KB
