Hi
I could use some expertise.
Last Thursday I replaced a dozen rivets. I have attached a picture of the rivets used which are aluminum 1/2" length 3/8 diameter closed pop rivets.
Before I inserted them in the hole I coated the inside of the rivet with 3M 5200 adhesive. I used an air riveter to set them.
I then went fishing Saturday through today (Monday). When I got home I refilled the boat with water to verify if any of the rivets were still leaking and 6 of the 12 are.
I use the same technique for all the rivets so where did I go wrong?
Are the rivets I used correct?
Should I have used 3M 4200 instead of 3M 5200?
For the leaking rivets what do I do at this point? Do I drilled him out sand the adhesive off ( can I) and reinstall them or just put more adhesive along the edge of the rivets?
I appreciate any help.
Thanks
Alex
Thanks
Alex
