Blackdogxx
- Joined
- Aug 12, 2012
- Messages
- Reaction score
- 0
I cannot upload a pic, but here is the problem: At a shallow ramp w. pier to walk out on, and using a Corolla with a trailer behind and a 5' extension to the tongue, I can launch and retrieve without the tailpipe or rear wheels in the water. Good so far.
At retrieve, the tongue extension is under water and narrow. I need a way to get the flat bottom 14' jon boat on the carpeted bunks enough to attach the winch hook. And when I drive away I want 1) my feet dry and 2) the boat stable and partially on the bunks. The trolling motor is bow mounted and foot controlled (reservoir lake is electric only), so no option to 'power on' to the trailer and no helper.
My best idea so far is to back the trailer down close to the pier side, get on the pier, use a rope attached to the boat front and pull the boat between the 2 trailer guide posts and starting on to the bunks a foot or so. Then climb in the boat and pull it with a rope close enough to the winch to grab the hook and attach it to the boat front. I am considering that a small pulley attached to the boat side (rear) of the winch upright might make the pulling easier on the hands by multiplying the force and allow attaching the hook as I step on the rope or hold it (I may add plastic 1X4s on top of the carpeted bunks soon... to make them slick).
Any other good ideas? Keep feet dry, the entire tongue will be under water, 1 person and a pier/concrete shallow ramp, and no motor use is available. Those are the restrictions and don't even offer 'wading boots' as an option.
