- Joined
- Nov 15, 2023
- Messages
- 206
- Reaction score
- 255
- LOCATION
- Green Lane Pennsylvania
My thoughts on the Garmin Force.
Unit came packaged very securely. Installation was fairly straight forward. The unit is loaded with features. Pairing with my two ultra units was no big deal though Garmin makes everything a little more complicated than it needs to be. First thing I noticed is how quiet the actual motor is, and how noisy the servo motors that turn the unit are.
The good.
The display on the motor is nice and easy to read.
The motor is very powerful and can get my 16’ crestliner storm fully loaded over 3 MPH.
The ability to network and punch in a waypoint and have the motor take you right to it is nice and it does it very well.
The integrated GT 54 transducer works perfectly.
The Bad
The motor wants to jerk when turning. Weather using gesture control, foot pedal, or fob, Not near as smooth as my 20 year old Terrova.
The anchor lock is a joke, the thing jerks and spins constantly weather in wind or dead calm water. Constantly turns to its limit and quickly spins back.
Heading hold does not take you in direction you set, at times turning 90* for a period then tries to get back on course.
Noisy servo motors.
I’ve been in the phone with Garmin and did all the recommended “ fixes” that resulted in not much improvement.
The foot pedal is laid out that accidentally pushing anchor lock and heading hold is easy to do.
Bottom line is this motor is a huge disappointment. For 3500$ you should get a motor that works perfectly out of the gate, not have to spend hours on downloads and updates, recalibration, reset servo zero, etc, etc, etc.
If you run Garmin electronics and are considering this motor, the built in compatible transducer and ability to network is not worth the inferior performance of the rest of the motor.
The good.
The Bad
Noisy servo motors.
