Rivet Length?
Backslider
Central Idaho
I have to replace a couple dozen solid rivets on my boat. How do you figure out how long of a rivet to install? Do you use a solid rivet that's 1/8" or 1/4" longer than the sheet metal's thickness?
Thanks for the help!
Id go with the 1/4" reveal. This will give plenty of material to mushroom over and give a good connection.
crazymanme, are you referring to 1 1/2 times the diameter of the shank of the rivit?
crazymanme, are you referring to 1 1/2 times the diameter of the shank of the rivet?
Yes, so if your rivet is 1/8" that would mean you need a 3/16" of the rivet sticking out.
This is aircraft standard.
That sounds better.
