yup got the rivets from tractor supply!! Figure if i break a drill bit id be pissed to go buy one cause i live in the woods and have to "travel into town" just to get anything lol.onthewater102 said:Got enough drill bits????
Those are the aluminum/aluminum rivets I was speaking of earlier.
DaleH said:I find that by "sneaking up on the torque" (actually breaking point) on those aluminum body/aluminum mandrel rivets, rather than setting them FAST ... that one can get them pretty darn tight. They do not replace solid rivets by any means, but should be fine for sub-structure installs. FYI, on that Aircraft Spruce website, there's some guidance on the number of rivets per inch to hold the material used as needed for the designed sheer stress rating.
THIS ... snug, then re-gripping or 'choking up on it' a couple times! Maybe its keeping the toolhead only a 1/16" or so from the pull that makes it tighter, i.e., less shaft under tension? But I find it works!Shaugh said:I seem to get the best results when I tighten the rivet just snug first, then open the gun and re-grip for the final slow pull. Don't be in a hurry. Going slow helps get them tight as possible.
