Thank you for all your help. After unboxing the motor, I discovered that it already has starter cables preattached. They are small gauge and look like maybe 6ga. Definitely not 4ga. Anyway, after seeing the control wiring harness that came with it and knowing the mess of spaghetti when I mount the control to the side console. I'm going to have to built a small cover or at least zip tie everything up in the stern corner out of the way. This will be a good spot to mount a few terminal lug posts to run the factory cables to and then from there to the starting battery. Being it's a 14ft jon boat, I want to keep it simple. If I ran all accessories at the same time, I think I'd have a hard time making even a 20 amp load. So I think I'm just going to use one battery as my battery for starting, nav lights, bilge pump, and fish finder. Not too concerned with running a battery completely down and not starting the motor as this motor is also pull start. When in doubt, follow ABYC guidelines (as one poster suggested).
