maintenanceguy
I have a old PolarKraft 1751 john boat. It had a plywood floor when I bought it. The previous owner added a lot of aluminum angle to the floor to make it level and laid a carpeted plywood floor on top of the added angle iron. Today, I drilled out the rivets for the flooring support system and stripped it all back to the original ribs. It's easier to walk now but the ribs are still in the way.
Here's what I want to do:
I want some sort of rubber or foam strips that I can lay directly on the hull between the ribs. The ribs are 1-1/2" tall. If I can find some sort of rubber floor that is approximately 1-1/2" thick, I'll cut it into strips and place it between the ribs. The combination of rubber and ribs will form an almost level floor with nothing sticking up to trip over. After each trip, you could lift out the strips and wash everything down.
It seems so obvious. Somebody should already make such a thing. I've had rubber gymnasium floors installed before and the product is a foam under rubber. It would work except that it's only available in 8mm or 10 mm thickness, which is no where close to 1-1/2". It's also very expensive and very heavy. I don't want to add 300 lbs of rubber to my boat so I'm looking for something less heavy.
I'm hoping somebody knows of something or has a brilliant idea about what material would work.
