I have a 70lb riptide on my boat, hand control. I definitely didn't want a foot control, and wireless control was out of my budget at the time. I don't regret my choice at all. Mine is simple, with minimal moving parts to break, rust, corrode, and it's stout.
I caught a stump running downstream in a creek at about 6mph this winter. It hung up so good that I went off the front of the boat into 49 degree water, and when under the full load the TM prop was just about touching the keel of my boat. I know because I got a good upside down view of it right before I hit the water. I then used the motor housing as a step to climb back in (me-200lbs, 4 under layers and insulated overalls soaked to the core- about another 30-50lbs). Once in the boat I freed the TM from the snag, used it to navigate out of the creek, and have used it several times since with no trouble. The composite shaft truly impressed me that it didn't suffer any damage.
