Gary Roe said:
I want to install jon boat seats directly on the boat benches. But jon boat seats don’t come with pedestals or swivel bases. So what should I do now? Anyone have suggestions for me? Thanks!
Hello Gary, my guess would be that it would depend on the design of the seat you are considering buying or already have if they can be installed with screws or bolts directly to the bench seat.
I haven’t found a seat that connects directly to a bench seat or that comes with a swivel or pedestal mount. Could be some out there but I’ve only seen the swivel or pedestal sold separately.
If you don’t want a swivel or pedestal then one approach I would suggest is to mount the seat securely on say, 1/2” plywood or a metal plate that is strong enough for supporting a seat. I would counter bore the mounting hole on the bottom so that the hardware is flush and lays flat. Then bolt the plywood or metal plate to the bench seat.
The bench seat in my Jon boat is enclosed so I’m using 1/4-20 rivnuts and 1/4-20 stainless screws to mount a swivel plate.
You may be able to fasten the seat directly to the bench seat by installing rivnuts in the bench seat that align with matching fasteners for the seat. May have to use wood washers between the fastener and the seat for additional surface area and strength. I would make sure that the seat has enough structure around where the fasteners would go and is strong enough to carry the weight of a person without the seat separating from where it is fastened. Also have to decide about not being able to return the seat once you drill into it!
Hope some of these ideas may help and be sure to check out the ole utube to check out any ideas there as well!
