Skidz
Hey folks I was wondering how many folks had an SI unit and if they had any advice as to the transducer mount. I have an older FF that I plan to mount on the front TM, and use the SI in back. But from what I have seen, the SI ducers are much larger than normal, and I'm wondering if this might cause any problems. I did measure from the transom to the closest point on the outboard, and at the bottom of the boat its right at 6 1/2 inches. I would have it off to the side of course, but I wanted to see how much clearance there was.
I would appreciate any advice or tips on set-up.
I haven't bought the unit yet, but have gotten the ok from the wife for the HB 898, which is most likely what I'll end up with.
Thanks!
Skidz
Thanks!
Skidz
