Macintosh
does your terrova (I think you said) have the us2 transducer? It's been almost a decade since I had a terrova, but at the time you could plug in a humminbird or a lowrance 2d transducer cable into a wire on the head of the TM and use the built-in transducer, so you can spin around in circles until you fall over dizzy without having a cable issue. Otherwise, there are 2 solutions--there are a lot of videos on this as well.Thanks for the advice.
My boat's top speed is only about 22 or 23 mph; and I won't be using the SI at that speed. More like no-wake speeds, so I'll be good on that.
I took the old Lowrance that was transom-mounted in the pic and moved it up to the trolling motor. I'm finishing up that install now. Need to figure out how I'm going to get the transducer cable to play acceptably with the spot lock and inevitable twisting around the TM shaft.
You all know how it is; life seems to intervene when we want to get the boat out. Maybe next week.
1) The older (pre 2017 or so I think) terrovas had a groove in the shaft large enough that you could use silcone adhesive and glue the transducer cable into the groove and THROUGH the mount 9requires disassembly). I am told the newer terrovas have a shallower groove and this may no longer be possible.
2) simply do it like you would any TM, cable tie or tape the ducer cable along the shaft, leave enough slack for the head to spin 2-3x, and then back along the mount into wherever you route the cable to the sonar unit. Usually the spot lock wont spin multiple full revolutions, I have heard people say it happened but have had a spot lock MK motor of one flavor or another for 10 years now and have never personally seen it. If you are worried about this take an extra foot or two of slack beyond the above, coil it a few times and TAPE it along the mount--you can tape it to a permanent fixture along the mount if you want, but the idea is to use an attachment that will hold it in place only enough so if it actually pulls tight your tape will let go allowing the extra slack to prevent cutting the cable. I saw someone do this and they said no interference, etc, but personally have never seen the need. My ultrex is simply cable tied along the shaft, has a big loop of slack around the mount, then tied to the mount until it gets to the sonar unit. Photo is a little dark but you can see the transducer cable along shaft and slack...this is an ultrex, but same thing with spot lock and going around the mount:
