smackdaddy53
You arent the first to say that so I suppose they are out of the question. They are expensive anyway.RiverBottomOutdoors said:I put 3 tempress hatches on my last boat. All 3 leaked in the rain.
Thanks! The OD green has to go! It is coming together nicely.RiverBottomOutdoors said:Damn...that's sexy looking in that last pic.
The tunnel per specs should be 20" long and 16" wide at bottom/14" wide at top with 45 degree sides so where the jet foot sits 12" back from the transom I should have to cut out 8" of the bottom of the hull and however deep the tunnel is at that point. I am going to have the tunnel cut out of 1/8" sheet and take it to my buddies shop and have it bent in a sheet metal break and find out where it sits in correlation to the hull. I plan on welding the sponsons on first, then figuring out how the tunnel/splash plate will fit past the transom/hull bottom and between the pods. The pods/tunnel will come together as a unit like an extension of the hull.Country Dave said:Looking good, =D>
Cutting the hull and transom out to fab the tunnel is going to pretty cool. How deep will the tunnel be and where will it start from midship? I know you said it’s going to extend out between the sponsons/float pods.
Port Mansfield to Sabine so far but mostly the middle Texas coast. My buddy and I are hitting some back lakes on Friday near Port O'Connor for some trout, redfish and flounder hopefully.Lonestarluck said:This is definately one of the coolest boats on this site, great work can't wait to see it finished. You may have already mentioned it but what area of the coast do you fish?
There are a few for sale down here but im sure you wouldnt drive to Texas for one. Youd think Florida would be full of them.Country Dave said:Looks cool, 8)
That is a great deal. I’ve been looking for a poling platform but haven’t found one yet.
bigwave said:I would check these guys out.......www.qualityttops.com They do very good work......highly recommend.
That is all you need! It would be hella cheap and still functional and surely you would make it look good after seeing your previous work.Country Dave said:bigwave said:I would check these guys out.......www.qualityttops.com They do very good work......highly recommend.
Thanks Kevin,
If I can find a decent used one that will work or one that I can modify and the price is right I’ll buy it. Otherwise I’m just going to fab one myself and have my friend help me weld it. I’m thinking square tube and white powder coat. :mrgreen:
