Looking to add my inflatable SIB which is 10.5ft and weighs in at 150lbs or so to the roof of my hardtop on my 16ft aluminum boat upside down. I know the roof can support it as I have climbed up there and its rated for 300lbs and I can extend the roof with a bolt on bracket using a quick release pin which will go thru the bench seats on my inflatable and secure it nicely. not worried about looks or the inflatable flying off but am worried about increasing/raising the center of gravity of my aluminum which weighs 700lbs dry (hull weight) without engine (engine is another 400lbs+300lbs or so gear/fuel).
will 150lbs on my hardtop roof cause my aluminum boat to become top heavy and cause problems in rough seas ? hardtop is about 5 ft high above the boat sides.
Specs of the aluminum boat are : Beam 6'-9", Freeboard 28", Deadrise 18°, Hull (lbs) 700, Bottom 3/16" x 6'-0 5086, Side 1/8" 5052.
im basically going to be using the inflatable as a lifeboat in an emergency so i would rather carry it inflated on the roof out of the way then stuffed into a bag and rolled up near the front seats which then requires 5-10min for inflation in an emergency.
any thoughts ?
any thoughts ?
