BottomDweller
Wondering how much of an issue I have with the transom I just replaced. My boat is aluminum. My transom is wood. I used stainless steel bolts to secure the wood transom board to the boat. Is this going to cause alot of problems? Do I have an option here? It seems that using anything other than stainless steel would eventually rust out but stainless does cause some corrosion with aluminum. My project is completed currently and I have secured my bolts with 3m 5200. I would hate to remove everything but will if this is going to cause alot of problems.
Another member mentioned the problem here, hence my concern.
