ureallyfloatmyboat
- Joined
- Sep 22, 2012
- Messages
- 8
- Reaction score
- 0
I finally took my 12' 1967 Sea King out for the first time after spending a month doing some basic work on her...transom and bench seat replacement. Everything went well! Man, it was so exciting taking my very first boat out...solo! I survived the launch and retrieval =D> . I even had the whole lake all to myself! My Minn Kota "The Fisherman" trolling motor worked out great. It's perfect for a small lake. I had great control with it mounted on the transom. I was pushing 3.5 mph! Unfortunately, my iphone conveniently ran out of memory for the first time #-o so I wasn't able to take many pictures or record many videos.
So, I do have a few minor leaks. A couple of the leaks appear to be coming from the seams on the ribs going across the bottom of the boat just in front of and behind the last bench seat. Also, some of the rivets on the inside and outside of the hull are leaking as well. Another leak appears to be coming from the corner on the starboard side where the hull and transom meet. As far as I can tell those are all of the leaks. I want to fix all of these leaks but I also want to strip the paint and restore the aluminum so I'm not sure how to go about doing this the correctly.
First, what is all of the stuff in between the seams and surrounding all of the rivets? Is that a sealant that is used on all aluminum boats? Is it something similar to 3M 5200? Should I strip the paint first along with all of the sealant (3M 5200)? If so, what is the most effective way of stripping the paint and sealant WITHOUT damaging the aluminum? I've read that stainless steel wheel brushes work well but they may remove pieces of the aluminum. I've also read that aircraft stripper is extremely effective but extremely caustic as well. Others have told me to use any paint remover. I don't have access to a sandblaster or power-washer so those are not an option. After I've stripped the paint and sealant how can I restore the aluminum without damaging it. What should I do after I strip the paint and remove all of the sealant around the seams and rivets? The seams and rivets will be better exposed so should I apply fresh 3M 5200 to ALL of the seams and rivets again? I'm new to all of this so I could really use some expertise.
Thanks.
Here are some pictures of the leaks and the "maiden voyage".
Thanks.
