After some issues with motor I removed the oil injection and wen to mix. Removed tank and wiring as well as sensor with light. Motor runs great but I need to know the wire to disconnect to prevent
the motor from going from 3 to 2 cylinders. The motor is recognizing low oil but do to mix I need to disconnect that sensor. Having trouble on which wiring it is. I believe it is black with red or pink stripe that goes up to near carbs. Is there anyone that give me some help. Thanks in advance.
