Ok thanks pappy it is empty I am taking it apart the cyl was leaking at the topPappy said:Sure.....with the trim all the way to the top you fill until the fluid runs out the hole you are filling from.
Can never fully empty those systems so there is not a good exact answer.
Nope the hard way lol too it out and put on the benchPappy said:Chances are the valve body and reservoir under the pump still has plenty of fluid in it. Hopefully you just disconnected the ram at the top and unscrewed the cap to repair instead of pulling the whole unit. Lots easier.
