Just kidding. But I was in the garage the other day and heard a sound coming from where my boat was. Realized it was my motor trim running non stop. No idea how long it was doing that but hopefully not long enough to damage the trim motors or anything.
Anyhow, when I bought the boat, the previous owner said the trim down button stopped working on the throttle handle, but trim up still worked. Instead of fixing it, he ran his own trim down button and mounted it next to the throttle control. I figured I would get around to fixing it properly, but you how that goes.... If it works....
With that background, I realized the down trim button on the throttle handle WAS in fact working now if I messed around with it, and it would stop the motor from trimming for a few seconds, then it would kick back on on its own. I messed with it til I got it trimmed down to a workable position and disconnected the battery.
So basically, that was a long winded way of saying, how do I get this fricken throttle control arm off? I'm semi confident the wires are messed up on the switch and since we had some bad rain storms recently, some moisture got into the switch and kicked trim on.
Attaching pics of throttle control along with previous owners down trim hack button.
I found the secret screw cover and got the front unscrewed but not sure how to get the arm off. The push in neutral button in the middle has me thinking it has something to do with that, but I'm doing my best to not break anything.
Other than drilling out all the rivets on the fricken panel it's attached to, I'm stuck!
Sent from my SM-G975U using Tapatalk
