finally got/took the time to check out the TM after going fishing this am. When I went to take the TM prop off, the black cover/nut was loose, I could easily turn it without any tools. Pulled the prop off, no fishing line behind, only a clean shaft, no rust, crud or crap. Put the prop back on, tightened the nut and tried it, no noise, but don't remember it making any whine before when not in the water when I was adjusting the TM when the pull rope broke last month. I did use speed 5 this am, and it did the same whine, but did not after checking behind the prop for crud. Any other ideas or suggestions?
