have a MG pro series 43lb'r 5 speed on my tracker PT175, and the pull rope to release the locking pin broke yesterday :x , could not raise the TM up for loading the boat on the trailer, so had to just raise the head/shaft/motor up via the thumbscrew. Has anyone had to change/replace their pull ropes, if so, how did you do it.
It looks like a portion of the mount fits down into a U shaped channel (the main mount) and in turn, the locking pin is under/inside this U shaped channel and I don't have access to it. I can ALMOST get the locking pin to release using some thin bladed screwdrivers/tools, etc., but not quite. Do you have to actually take the head/shaft/motor off of the mount to gain access to the locking pin or what ??
