theyyounggun
After doing a little snagging in the rain I got the seat mounted. Im going to try and build a extension out of PVC for my TM that way it reaches back to the bench.
I can't use those earmuffs like you said but there is a different style I can use. And the screw. But I was lookin at the cavitation plate and it looks like it sits pretty level with the bottom. I just have to by a bolt at lowes so I can make the OB sit perfectly vertical.inlovewithsurfin said:great find on the outboard! looks like a long shaft? (if so you will need a jack plate to raise it up higher on your transom) i have been wanting an older mariner soo bad! they are pretty similar to a yamaha... i saw you say you don't know where to put the eaI muffs? this outboard doesn't use earmuffs.... it has a screw that you remove down by the propeller that you screw in an attachment that goes to a hose.
good job on the progress and am looking forward to final pictures
