miketheknife
Just purchased 1969 Rich Line Model 15 with a home made trailer. Here is a pic showing the problem.
If the boat is centered over the roller, the outside keels are centered over the bunks. I assume the bunks should be centered between the edge of the outside keels and the rib rivet lines. Is this OK?
Also, the bunks are a little short, They stop about 4" short of the transom.
Being new at this, I am open to suggestions.
Thanks,
Mike
Thanks,
Mike
