Trailer Hub Washer
DiveLiberty
Liberty, MO
Replacing my trailer hubs with a CE Smith hub kit. Wasted $30 by ordering the wrong size, now the correct size still isn’t working. Figured out I’m missing the washer that goes in between the castle but and the outer bearing, so the outer bearing is falling out of the hub a little bit.
Any resident trailer experts know what type of washer is needed as far as material? Do I have to order a special trailer hub washer online? Or can I just try and find one that fits from the hardware store?
You need a washer that has the keyway tang on it or the milled slot in it to keep the washer from turning on the spindle. If you use a regular washer it will spin and rub on the back side of the castle nut causing it to leave metal shavings in your hub decreasing bearing life.
I’ve been servicing the bearings on my boat trailers for over 30 years. My axles don’t have a key slot so a normal, SST washer is all that has ever been on my hubs.
SST?
