gogittum
I've got a dandy going here that has me shaking my head and laughing/crying.
Last week I bought an older 12 ft MirroCraft tin boat with 15 hp outboard, sitting on an older trailer. Basically sound and can be used as is....almost...but there are a few things I've been working on "to make it better." As expected, lights on trailer were u/s, so tossed 'em and bought a cheap kit online that has both tail lights, both marker lights and about 25 ft of 4 strand wire with 4 pole flat plugs.
Late yesterday, I re-wired the trailer and mounted the lights. Lights wouldn't come on, so figured with all the rust and layers of paint I wasn't getting a good ground - the usual cause.
I drilled and tapped holes by each light and ran separate grounds to each one, then checked ground at car plug and showed power at all 3 terminals with a 12V test light. Plugged in trailer and no lights.
I clipped the grounding alligator clip to my new main ground on trailer, then poked the needle tip thru the insulation on each brown (tail light) wire and the yellow and green turn signal wires.....this is on the trailer side about a foot downstream of the plugs at hitch.
All showed power at the test light.....but still no lights on trailer - on the far end of the same wires. Went down to each light individually, clipped to ground and probed thru the insulation. Nothing on any of them. HTH can this be ?? I've wired a lot of trailers.....and lots of other stuff, too, and when you have an unbroken wire with power at one end, then there will be power at the other end, too, right ?? Hah.
I walked away from it for a while, then went back with a clear head and fresh viewpoint. No change. I don't know WTH to think. Can't be the bulbs (these are cheapie non-LED) cause no power is showing where wires enter lights but power is showing at other end of wires. Aaaarrggh ! ! !
